if you have a look at the top pics you will see codings r same but v12 says invalid
could do but thats just pain in the ass
Again, for the 3rd time, the CNC controller area is irrelevant for your use case.
It is not connected to your board.
It doesnât know what your board understands.
Donât use it.
What matters is in the file.
If you donât want to attach them and donât want to look there to see the differences, I donât know how else to help you.
I hope you get it figured out
It does not matter what EstlCAM is telling you because you are NOT using EstlCAM as the controller!!!
Ryan tests everything he sends out.
Also, you can bundle the quotes and donât have to make three posts.
Can you zip and upload your file for us to look at please. We can tell you right away if you got your starting gcode correct.
Hello,
I think there are a few things mixed up:
- Youâre using Marlin to control your CNC - not Estlcams integrated controller.
- Estlcam and Marlin are both CNC controllers but other than that have little in common.
- So codes that are invalid for Estlcam can be valid vor Marlin and vice versa.
- So while Estlcam can create CNC programs for both Marlin and itself it can only validate the code for itself but not for other control systems. You need to check the programs for Marlin with Marlin itself.
I have no experience with Marlin and if it can report what exactly is wrong or missing.
But if you have a working CNC program created by V11 and one that is not working created by V12 the most simple way to find the source of the issue is to compare those 2 files with a text editor and see what the differences are.
Christian
framed rose e12 acm.gcode (151.7 KB)
This is in the top of your V12 file
;Project framed rose
;Created by Estlcam version 12 build 12.110
;Machining time about 00:39:13 hours
M0 Attach probe ; Pause to connect touchplate
G38.2 Z0 ; Probe down to touchplate
G92 Z0.5 ; Set new Z position to thickness of touchplate
G1 Z2 F900 ; Lift off touchplate
M0 Remove probe ; Pause and wait for touchplate removal
This matches what is in your picture above.
I assume this matches your V11 file as well, but it was not attached to verify.
This means, V12 is doing what it is supposed to.
You need to approach troubleshooting this differently.
If you take the the V11 file and V12 file and run them back to back, I would expect the start codes to work identically
tried that ran the v11 file sweet as. put in v 12 and it wont stop at probe just keeps screwing down on the Z axis have than cut 3 different projects using v 11all probed sweet as . V 12 just wonât probe any file
Then what is the difference between the 2 files?
you didnât post the v11 file for comparison.
They are just text files. The estlcam version number doesnât matter if the text inside is the same
Is the problem happening during the initial probing or during the later tool change?
This is the tool change gcode from the file:
M0G28 Z ; Raise Z axis
G0 X0 Y0 F2520 ; Drive to tool change side
M00 change tool, probe ; Pause to change tool and attach probe.
G38.2 Z0 ; Probe to touchplate
G92 Z0.5 ; Set Z to touchplate thickness
G00 Z5.0000 F500 ; Lift off touchplate
M00 remove probe ; Pause to remove touchplate
I donât know the Marlin-specifics of gcode but that âM0G28 Zâ seems odd to me.
Yeah that M0 shouldnât be there. Should just be G28 Z ; Raise Z axis
Here is what the docs show for marlin tool change for a LR3/4
M107 ; Turn fan 1 off IOT relay
M106 ; Turn fan 1 on IoT relay
Looks like he is missing the G92 X0 Y0 but that shouldnât have any effect on the probing
Here is whatâs in the docs for Marlin start gcode for LR3/4
G92 X0 Y0 ; Set Current position to 0 on the X and Y axes.
M106 ; This will turn on an IOT relay to start a router or vacuum
No need to have the M106 if he isnât using it. Not sure why he took out the G92 but as long as he is zeroing it some other way it should be fine. Much easier when its just all there in the start Gcode to me.
no 8 framed rose.gcode (63.8 KB)
on initial probing
mo g28 hmmm
if you look at top photos showing text settings for v11 and 12
theres no mog28 in text . i copied and pasted it from the milling page.
so where or how would the m0g28 end up in the final code ???
again hmmmm
the G92 is in the text in my settings
as you can see in images
but missing in the file ?
got me stumped
yip marlin highlighted no postprocessors
ive opened v 11 and 12 side by side triple checked every setting should all text boxs for laser under texts be empty in 11 defult is they are empty 12 they have text
Laser Texts entries are only used when the Laser tool is being used. All Text entries will be included in the G-code as written (v11 and 12). If you need something to preview and step through G-code give https://ncviewer.com/ a try.
No itâs not. The only difference is what appears to be a pointless/invalid G00 line that had to have been in Texts when the G-code was generated.
hey dave
, , a previous comment said the g92 is missing from the file , ur saying its not missing from the file ?
out of all the responses still no answers as to why v11 works fine but v 12 wont
