Hello,
I have a arduino uno with CNC shield and want to use it directly with estlcam (not with repetier)
What and how do I configure the arduino. All my hardware comes from here.
Thanks.
Barlouka
Hello,
Thanks.
Barlouka
I think you will be the first one going that route. I am not sure what you need to do. I am pretty sure it runs grbl. There are step by step instructions in ESTLCAM.
I’m currently building my MPCNC with this setup… Uno and CNC Shield running grbl. I don’t plan on using the MPCNC for printing or running jobs from SD cards, so I think the Mega/Ramps setup is overkill for me.
I currently have everything moving. I’m getting limit switches setup and getting familiar with the CNC workflow. I hope to start cutting this weekend.
If you want any info on setting this up, take a look at the xcarve or shapeoko communities, as they primarily use an Uno running grbl.
http://x-carve-instructions.inventables.com/step14/
http://www.shapeoko.com/wiki/index.php/Grbl
Hi,
you don’t need to configure the Arduino itself - Estlcam will do all this for you:
Christian
