nuril83
(Nuril Anwar)
September 15, 2020, 1:20pm
1
I got this error msg during uploading the sketch. What should I do?
Here is the error msg
Arduino: 1.8.13 (Windows Store 1.8.42.0) (Windows 10), Board: “RAMBo”
Sketch uses 662 bytes (0%) of program storage space. Maximum is 258048 bytes.
Global variables use 9 bytes of dynamic memory.
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
An error occurred while uploading the sketch
This report would have more information with
“Show verbose output during compilation”
option enabled in File -> Preferences.
banjopete
(Brent)
September 15, 2020, 3:14pm
2
What are you trying to do? Are you running the cnc tethered or with an lcd? Trying to cut something?
jeffeb3
(Jeffeb3)
September 15, 2020, 3:46pm
3
This is saying it can’t talk to the microcontroller. Make sure it is powered and you have the right port.
That is a little weird. It usually says more like 53%. But I don’t usually pay attention.
nuril83
(Nuril Anwar)
September 15, 2020, 3:50pm
4
I’m trying to install the firmware. Do I need to install the attached lcd during installation or not?
jeffeb3
(Jeffeb3)
September 15, 2020, 3:51pm
5
You don’t need the lcd during installation.
nuril83
(Nuril Anwar)
September 15, 2020, 3:53pm
6
I’m using 12v 15amp power supply Is it ok?
jeffeb3
(Jeffeb3)
7
The fact you have a tab for sketch_something makes me think you don’t have the project open correctly. You should unzip it, open the Marlin/Marlin.ino file there and then compile/upload from that window.
jeffeb3
(Jeffeb3)
September 15, 2020, 3:54pm
8
That should be fine. Do you have the polarity right? Are there lights on?
These things are pretty hard to break. There shouldn’t be any way to break them over USB. I am guessing you have two problems. 1) not the right source code and 2) a connection error.
nuril83
(Nuril Anwar)
9
I’m referring to this while installing the firmware - https://www.v1engineering.com/marlin-firmware/ i get the same error msg.
nuril83
(Nuril Anwar)
September 15, 2020, 3:58pm
10
Oh maybe my power supply is dead. No light on my mini rambo. Thanks @jeffeb3 @banjopete . I’ll update after getting new power supply.
banjopete
(Brent)
September 15, 2020, 4:06pm
11
Good luck, you are in good hands.
