So I screwed up and forgot to order the endstop wires in my V1 order… and I really don’t want to re-order and pay shipping. Does anyone have an Amazon link to something similar?
I’m in Australia, I had to get an extra couple as ui messed a few crimps up.
This is what I used.
I assume you ordered the wiring harness from V1. That means you are only trying to bridge the space between the end of the harness and the switches. At the harness end, you want Dupont connectors. You can 1) order long Dupont wires, 2) order short Dupont wires, cut them, and extend them (solder) with other wire, or 3) get a Dupont connector kit, put Dupont wires on the end of some wire. Assuming you have some wire around, #2 will be the cheapest solution.
On the switch end, I recommend soldering to the switches. I think V1 in his instructions recommends this as well. If you really want a connector, then the right size spade connector wil work.
Here is an Amazon link to Dupont wires in different lengths.. Unfortunately, you cannot order just a small number.
Note that polarity does not matter, so no stress about the rotation of the connection.
So for all those who will need this in the future, I found a great source for Dupont-style wiring and connectors on Amazon. Here is the link.
