End mills on thin wall round tube
So here I am thinking about altering my Cnc plasma cutter thought to swap it out for a router.
Has anyone milled round tubing on a rotating axis in here before ?
Like maybe a tapered end mill so you can plunge through the wall then cut the profile. I feel like the r load on the bit would be too much as it would be cutting with about 50% step over. Anyways just a question to see if someone has done this.
Hmm nope, but if I understood correctly could this help? https://youtu.be/FhsAKh7Dkm0?si=Hf9xPftDtDcz5Blb
Yes that’s the machine that Inspired mine but I am trying to get away from plasma if it’s possible(HAZ) At this point I don’t know that the machine will be rugged enough. Will have to give it a try I guess.ideally I would like something that can cut 4130 thin wall small diameter tube. The machine the guy built is a bit on the big size.
I want a fiber laser!
Me too lol although I feel like I would get myself in trouble.
Check the government auction sites there was a trumph one a while back.
Monport or similar fiber laser module attached to a LR4?
I want one of those UV lasers. :sweat_smile:
I want a laser!!
I want an ice cream cone.
undefined - Imgur
17653252782546453068799137544100
Brain freeze
