I am planning on a small enclosure for the RAMBO board, PS and a little bit of logic. I’ll be using the MPCNC only as a router. My question is about the cooling requirements of the RAMBO board. Knowing how sawdust has the ability to get anywhere, I would like to use a sealed enclosure, but I am concerned about proper cooling of the board and PS.
Does everyone use a fan, natural cooling or no cooling?
My board is mounted in a case upside down on the bottom of the spoiler board inside a little cubby so that the fans push air up onto the board. While some dust probably makes it up to it, it’s minimal compared to what gravity is pulling down.
I have acquired a nice Rittal box to house the board, PS and E-stop relay. I’m planning on adding an E-stop button, a Reset button and a switch to Start/Stop the router itself to the cabinet door. This cabinet will be essentially airtight with cable glands for the entry/exit cables.
Unless I find some required cooling info, I think I’ll try it tight and monitor it’s temperature for a while. I can always cut in a outlet fan and a filtered inlet later.
