Does anyone know how to enable the additional UART near the bottom right of the board, or is it enabled by default? (in the Marlin config)
AFAICT the USB (virtual) serial port is -1, the TFT 1 and the ESP01S port is 6. I could not, however, find out, which one the UART is.
On a related note, does Marlin support 4 serial ports? I know 3 ports was added semi-recently, but I’m planning to add some peripherals to my MPCNC
Regards,
Rockfish
That is the serial UART that the RepRap firmware port enables on the SKR Pro for the PanelDue.
I know that you can enable that one instead of the touch screen port… but not sure why you’d do that.
Sorry, doesn’t answer the original question, but at least confirma that the UART works…
Seeing as that is labelled UART3 I think I would try adding -
#define SERIAL_PORT_3 3
to your Configuration.h
It (if it works) will talk at the same rate as serial port 2 ie 115200 or 250000 depending on what your #define BAUDRATE xxxxxxxx is set to.
Mike:
I’ll try that once I get the chance and update my findings here
Regards,
Rockfish
Update: It does seem to be port 3.
Now I just need to find out why my TFT thinks there is no printer attached when I connect my peripheral… Maybe because I send M154.
I did also define AUTO_REPORT_REAL_POSITION, M114_REALTIME and REALTIME_REPORTING_COMMANDS, so perhaps it’s one of those options.
A little annoying, since I have been unable to start a job because of this, but I’m sure it’ll work itself out
Regards,
Rockfish
