Hello again all,
I’m putting together a control box to house all/most of my electronics. What I want to do is mount 3 toggle switches for X Y Z stepper motors to be able to enable/disable each separately if I need to. I looked on google and didn’t find any info on how to wire the switches. So I ask you lovely people if anyone has done this and how. I am running external drivers on my ramps 1.4 board.
I’m thinking I can either switch 1 coil wire from each coil (2 wires) using a DPDT toggle switch, or switch the +12V of the driver. I’m also thinking that switching the driver on and off would/may not be that good for the driver, so I’m leaning towards my first option.
Is there another, better option that I haven’t thought of?
I use the LCD and don’t have a laptop/PC next to the machine to do it through repetier etc. I really do prefer to do it manually through switches, probably more than having the option on the LCD menu (which mine doesn’t have).
Any advice greatly appreciated as always
). So I think that’s actually safe. It’s definitely a “do at your own risk” type of thing though. You don’t see me doing it. My biggest complaint about the enable pin approach is that Marlin has no idea that it’s not controlling the stepper anymore, so it’s builtin logic about state when disabled (like homing after enable) will be completely off. If, for example, you had the Z at Z=2.0, and you switched off the Z, moved it down to the workpiece, and turned it back on, then Marlin would think that a) it’s at Z=2 and b) There’s no reason to think that it’s not perfectly correct.
If it’s crazy enough, I just might want to do it myself! I’d at least talk about it occasionally.
