Hey all. I am struggling with ideas for the case/enclosure. I have the SKR 1.4, RPI3b, SSR and TFT24. I like some of what I see on Thingiverse, but I would like to see what you have done. I can make an external case but would prefer it to be mounted to the lower bracket and move with the gantry as to minimize wiring
The 5015 fan provides a cooling airflow to the drivers. The opposite side of the case in this picture has no venting because it’s going to be the top face, and I don’t want to let excess chips/sawdust get into the enclosed space. For this design, the 2.5D flat plate will be fastened to the table vertically. There is a channel that the fan sits in, and goes under the line of drivers 6.5mm deep, and the board is a further 1/4" off on standoffs, so most of the directed airflow is at the underside of the board, as this is where the Duet instructons say to direct cooling air. I may decide to add heat sinks, but that should not be necessary.
If I were to add a Pi to this, I would probably increase cooling with a second fan, or use a higher capacity fan and add an air filter.
You might want to consider some type of filter on your fan even with it on the bottom.
I designed my enclosure to pull air in from the bottom and when I opened it the other day I was surprised to see a bunch of fine sawdust in the enclosure.
I have two fans blowing into my case. One one my controller and one on my pi.
I shared your desire to keep everything I could on the Gantry as I wanted to remove the gantry when not in use. I managed to shoehorn in an SKR 1.3, A Raspberry Pi3A+, and a power supply into my case. To keep the depth down I designed it to fit like a cup over the Y stepper motor. I don’t use an LCD but did put the wire runs and mounting holes in case I change my mind.
There are 2 cooling fans on the side and bottom that run in parallel from the SKR’s fan port.
It works well but its a pain to remove if I ever need access to the SD cards.
My kids friend told his dad that he thought I was building a bomb.
