Easy dust extraction remote
not sure exactly where to post this, hopefully this is close.
so today i picked up some “smart” appliance socket thingys. grid connect is the ecosystem. from initial looks, i’ll be able to use them to remotely turn on my lr4’s jp3, which can then automatically trigger the dust extractor to turn on. for now ill be manually turning on my makita router, however with the addition of an iot relay, i expect to be able to make the whole system more streamlined.
is anyone able to tell me if these
relays are easily adapted to the jackpot 3 board?
Yes, it should be. You would output from the pins on the JP3 to the input (green) connectors on the bottom. It is similar to the other one that many of us run.
