I leave the dual end stops alone unless i’m using an actual end stop switch. For activating sensorless homing I thought I saw a section somewhere else. It’s either or correct?
I haven’t done dual endstops with sensorless homing. I assume you would enable sensorless homing on all the drivers, enable dual endstop for X and Y. And then you’d need to set the dual endstop pins to whatever pins the sensorless homing is wired to.
Hit my first milestone today. I have all 5 steppers moving from both the lcd & repetier host.
The printer is happily melting plastic and my DW660 showed up. Other than a few bolts I’m back to waiting fo my parts to print.
I have a feeling that I don’t have all the marlin settings correct, but I’ll work those out when the machine is built.
Thanks again everyone.
