Driver help
Hello everyone, I encountered exactly the same problem -
Testing X connection… Error: All LOW
Testing Y connection… Error: All LOW
Testing Z connection… Error: All LOW
Disconnected.
SKR PRO 1.2 board
Stepper motors do not move.
when the M122 command is given
gives the following:
Connecting...
Printer is now online.
>>> M122
SENDING:M122
		X	Y	Z
Address		0	0	0
Enabled		false	false	false
Set current	900	900	900
RMS current	1602	1602	1602
MAX current	2259	2259	2259
Run current	28/31	28/31	28/31
Hold current	22/31	22/31	22/31
CS actual	0/31	0/31	0/31
PWM scale
vsense		0=.325	0=.325	0=.325
stealthChop	false	false	false
msteps		256	256	256
interp		false	false	false
tstep		0	0	0
PWM thresh.
[mm/s]
OT prewarn	false	false	false
triggered
 OTP		false	false	false
pwm scale sum	0	0	0
pwm scale auto	0	0	0
pwm offset auto	0	0	0
pwm grad auto	0	0	0
off time	0	0	0
blank time	16	16	16
hysteresis
 -end		-3	-3	-3
 -start		1	1	1
Stallguard thrs	0	0	0
uStep count	0	0	0
DRVSTATUS	X	Y	Z
sg_result	0	0	0
stst		*	*	*
olb
ola
s2gb
s2ga
otpw
ot
157C
150C
143C
120C
s2vsa
s2vsb
Driver registers:
		X	0x00:00:00:00	 Bad response!
		Y	0x00:00:00:00	 Bad response!
		Z	0x00:00:00:00	 Bad response!
Testing X connection... Error: All LOW
Testing Y connection... Error: All LOW
Testing Z connection... Error: All LOW
I performed all the above actions,
removed the pin brackets, bent the contacts on TMS 2209
posting a photo of the board.
Hi, Please always start a new topic. While it might seem the exact same if it was, the solution should also work. Let’s take a look at your individual situation.
What firmware are you using, since none of ours only has three drivers? What are you using this for? Why not use our firmware?
Your power needs to go to the MOTOR pins as well.
Good catch Heffe.
Only half of your skr board is powered
