Sometimes F360 decides to set too safe clearance/retraction settings which causes Z axis to be too high and it fails down as the result.
Is there a way to change the behavior to pause/abort the job instead?
To avoid things like:
Not that I know of.
I usually change the Clearance High before send to post processor, and in Post, I change the retraction setting after tool change to prevent the machine from hitting the limit switch
