I’m sure the info is here, but wasn’t able to find the right search term to find it.
What is the distance between centers on the X and Y conduits for the MPCNC C type 23.5mm outer diameter?
Is it the same on all the variants?
Thanks
Andrew
Thanks
Andrew
The distance between centers of the 23.5mm version XY rails is 27.5mm.
Hello Ryan,
I have an very early 25mm Burly build, where I measured 2,1mm between the axis. I figured an error on my side and settled on 2mm. Now I’m checking on the updated parts in Fusion where it seems to be 25mm. Has there been a change?
Tank you,
Philipp
