Is it possible to set a Start/End Point for a cutting path in Estlcam while also having Holding Tabs on the same cutting path? Every time I try to set a Start Point for a cut and then try to also set Holding Tabs for the same path it deletes the Start Point.
If I try it in reverse and set the Holding Tabs and then try to set a Start Point it negates all of the Holding Tabs that I had already defined. I’m hoping there is a simple order of operations that I’m defying, or maybe a modifyer key trick or something.
Thanks guys,
I appreciate the efforts. It’s a bummer, there are a few things I wish Estlcam could do but it gets the job done so I guess I have to deal with the few deficites. $60 is way more affordable than the commercial software.
