Regretfully, all my prior tests were with both strut plates and these screws. I’ve dealt with sickness, joint pain, way to much on me, lack of time, etc, and so I just could not muster the motivation to try to get “before and after” testing done. So sorry.
Can we take this sentence out please. I really do not want all the new user Thinking they need to do this. I am not convinced it is super easy to keep dead flat (It wasn’t for me) and I am not sure if / how much it helps.
I am hoping to find time to rebuild my Full sheet while I am off this time. If so I will leave the screws out of it and run it for a while, Then I will go back and add the screws and see if I can get any noticeable amount of difference in a large beam. I did put them in on one of the beta runs and I didn’t find a noticeable difference on a 36" cut area.
I’m guessing we need to test this sort of stuff in aluminum at this point. Finding differences in wood with a 1/4 endmill is not going to be easy to see anymore.
Sounds good. I need to make some aluminum cuts with the LR4 anyway’s LOL. Who wants to buy a set of Aluminum LR4 Struts so I can see if its even worth offering
I have not tested it. I removed almost all the details from the post, and let it just be a statement and a couple photos. I added a disclaimer: “I have not tested whether the machine is stronger with these than without.”
At some point, one of the XY/YZ “Plates” are more likely to lift than the Beam deflect, I found this when mistakingly using flat tipped V carve bit and some downcut jobs on my LR3. Recently started thinking about strain gauges on YZ being needed when Beam deflection isn’t the bottleneck.
Love this, but I’ve been planning on cutting my own aluminum struts. So, question for the braintrust is - How thick does the aluminum need to be for rigidity. I’m thinking I’ll cut a 3 mm piece of BB ply or hardboard and paint it, then cut a 3mm aluminum piece for a total of about 1/4"? Is there any measurable advantage to going thicker on the aluminum? (At that length it seems like thicker will be quite a bit more expensive.)
Why both? The wood will be completely null if you are using aluminum. The most you can go is 1/4". but I think you would be good with 1/8" or 3/16" to save some cost
