##define X_bed_size question
Hello everyone,
I was wondering if we need to set:
#define X_BED_SIZE 200
#define Y_BED_SIZE 200
to what our cutting area is in Marlin 2.0?
I am familiar with Marlin with respect to 3d printers so setting these values seems necessary to me.
Only if you use dual endstops and want to home from more than 200mm away. I rarely change this as I am usually within 200mm of the endstop.
Ok, thanks!
I changed them values as my MPCNC was larger. Now I moved to a new (smaller) table and need to resize table accordingly. Bit it helps homing when you are far away.
It still trips me up on occasion with my homing. I am too chicken to reflash firmware because it works great now.
@jeffeb3, is this something you can set permanently with a gcode command or not? I’m never sure how that works.
I’ve not seen a gcode command for it. Maybe that should be something we PR into Marlin, since we are probably the only ones that have whatever sized bed you want. Volunteers?
Just for information, these dimensions are in mm.
Rob
So my cut bed is 600mm x 600 mm, dual endstops. do I need to set bed size? or just position start point. ??
You can do either.
If you want to be able to home when the core is more than 200 mm away from the endstops, you will need to edit/compile and flash your frimware.
The easier alternative is to just manually move the core in the X and/or Y directions (using the MOVE commands, or by powering down and moving it by hand) until it is within the 200mm limit, then homing from there.
sounds good thanks.
