Cutting to deep - software problems?!
Hey, the Lowrider is running pretty well so far! However, I’ve noticed that the cutting depth is always a bit deeper than set.
I know this could be due to curved material, but it’s consistently at least half a millimeter deeper than the set depth.
Could this be because the Z-probe thickness is doubling? The start gcode in Estlcam contains “G38.2 Z-110 F200 P0.5 (probe down set thickness)”
and the preferences stored on the ESP32 contain “probetouchplatethickness”: “0.5” - could this be the problem?
I’m also having a problem where the ESP frequently resets (the Wi-Fi connection drops and needs to be reconnected) or FluidNC simply switches to alarm mode – usually after homing or simple jogs.
I’m using FluidNC 3.9.9 with WebUI 2.
And is it normal that about 70% of the flash memory is occupied, with the index.html.gz file taking up most of it?
Thanks for your help
yes, the FLASH storage is very small. This is on purpose.
This is only the storage drive, not the running memory of the ESP32.
No, that setting is only used with the Probe tab. That G38.2 start gcode is independent.
If it’s going too deep, there are a few things that could be happening:
  1. It could be that the board isn’t secured to the spoilboard well enough. So, the probe is pushing the board down against the spoilboard more.
  2. You could be skipping Z steps so it’s losing Z positioning.
  3. Similar to #2, but your grub screws could be loose.
Post a picture of how the wires are routed to the Jackpot. If there are wires running over the ESP32, that will cause problems.
The alarm mode one is a bit trickier. You’ll need to show the terminal output when this happens. It can happen with homing if the switch is triggered from the start.
There’s also option 1 in a variant:
The workpiece isn’t secured well enough and the (presumably upcut) endmill is bending / lifting the work up
Thank you so much for the great advice.
It was a combination of a few things.
Firstly, the coupler for the Z-axis lead screw wasn’t fully tightened on one side.
I noticed a squeaking noise coming from this side, and it turned out the lead screw wasn’t turning smoothly in the copper nut.
The Z-axis lead screw occasionally slipped in the coupler when the X-axis beam moved up.
I cleaned and greased the lead screw and tightened the coupler.
I also discovered that my spoilboard was warped. A few more screws and I now have evenly deep milled grooves across the entire width. Over the full length is still slightly uneven, but that’s because my base plate is a bit warped – it’s not a big deal, though.
I couldn’t solve the connection problem, only work around it.
In AP mode, the ESP32 sometimes lost connection, sometimes during homing, sometimes during a simple jog, and sometimes when uploading a file.
The connection is stable in STA mode. Perhaps it was also due to my device.
I’m dissappointed that nobody told @Frosti94 to tighten the grub screws….:upside_down_face:
Jason did!
OOOOOW, now I am dissapointed that I can’t read properly :slight_smile: Thank you for the reprimand.
Man, you are quick!
