That 1.5” facing bit really makes quick work of smoothing off.
I’m making a large cutting board for the thanksgiving turkey.
Nice, where from? Saw…
Am currently using 1" surfacing bit from amzn. Larger bit with replaceable blades sounds helpful for larger jobs.
17”x22” cutting board
Four passes at 1mm has around 35% step over has took around an hour and a half and it’s about to start the last pass.
Can you hear the 660 struggling or is it doing good?
It doesn’t slack up a bit, no problem at all swinging a 1-1/2 blade cutting around 1/2”-3/4” per pass.
The vac however appears to be a different story. ![]()
Nice work, I’ve been surfacing with a 3/4 bit but a 1.5 would definitely speed things up.
Lol yeah the vac can’t keep up at all. It only catches about 1/4 of the shavings.
