Cura setting?
Was just looking for some input on Cura setup prior to printing my parts for MPCNC Primo.
My question is should I change my setting from Inside to Outside or use Outside to Inside?
I’m looking for more precision in parts diameter.
Someone can correct me if I’m wrong but inside to outside perimeters should be used for everything. There shouldn’t be any significant difference in part dimensions between either method but overhangs will be much worse with outside to inside perimeters.
You could probably pick and choose depending on the part but it’s best to stick to inside to outside.
I also used “inside to outside” to help overhang quality.
