hello everyone
new here (event a longtime reader) so please bare with me
I have salvaged couple parts from my cr-10 s4 mainly the board, a Creality v2.1 (to witch I added a fifth stepper to be compatible)
but the board only have 3 end stops so was wondering if I can switch couple unused ports to use as end stops to get dual y&z squaring
also want to add also either one or 2 SS relays to turn on the Dremel (not sure if I should put it directly or just the tube shaft is enough) and the vacuum, event mainly it’ll be used as a laser cutter with a nene 10w laser, but im not completely sure about the wiring of one ac to ac ssr that I was sent mistakenly from aliexpress
I wanted to use a 32bit board that I have laying around like the mks e3d with the an extension and with closed loop nema17 motors but read somewhere here that its not recommended, thought itll be better since there’s no skipping steps so it’ll work but maybe im mistaken
wanted to build the lowrider 3 instead since its newer but the project was delayed enough, and the table I have will be used for other stuffs so can’t have the aluminium bar fixed on it yet, and didn’t see any mixes or versions of the belts fixed on the side
would reaaaaaally appreciate your help with the build and thank you all for your efforts and to Ryan for the project
have a wonderful day
