Well, nobody is happy with my MPCNC’s anemic cutting area (including me, if I’m, so I’m looking at converting over to a LowRider. As near as I can tell, I can pretty much reuse my electronics, correct? And a lot of the hardware can probably be reused as well.
I wouldn’t say “nobody”. But there’s a lot of advantage to having a bigger build volume.
I used all the electronics from my MPCNC for my low rider. I bought new hardware though, because I can use the spares and I wasn’t sure how much I would get easily from the build.
Conveniently, you can cut the lr parts yourself :).
Mostly I’ve just been playing around with plywood/mdf. I built my MPCNC to have a 12"x12" cutting area. I want to be cutting at least 4x4, but I have enough room in my shop to do a full 4x8, so I’m probably going to do that. I’ll mostly be working in wood/mdf/plastic, but might try the occasional bit of aluminum, but that isn’t a requirement by any stretch.
My MPCNC was 2’x3’ and my low rider is 4’x3’. The low rider is more square and rigid at these sizes. I haven’t ever cut one huge piece on the low rider though. The biggest thing I’ve cut was actually on the MPCNC (my kitchen helper).
