conduit available
Hi
I have conduit available in my country:
Outside Dimension (mm)
"3/4 26.9
"1 33.7
What should i do with the print parts that have different dimension?
You have to find tubes one of 3 official mpcnc sizes before you will buy or print parts.
As last option, but for not big mpcnc you may try to find 25mm steel tubes used in furniture manufacturing. Usually it has 0.7-0.8mm wall thickness (it’s bad), but you may try to find it with 1.0mm wall thickness
Agreed, There are also typically 2 kinds of conduit thin and thick walled. If you can’t find one of the three sizes you can look into stainless steel tubing.
For the last few years I am pretty confident we have a size for every country.
Last case, let us know what country and someone a little more local might be able to chime in.
Are you sure your metric o.d. dimensions are accurate? 26.9 is slightly over an inch, perhaps 3/4" is a nominal inside diameter in your country? Perhaps the next size down would match EMT dimensions?
Thank you for replay.
I live in Israel.
I will check for stainless steel tubing.
Yes all the dimension does not match the desire MPcnc dimension
Hey Dubi,
I had the same trouble in the Netherlands. Needed to go stainless steel to get the 25mm OD tubing. None of the hardware stores had anything suitable, had to order online (which turned out nice, the cuts were very accurate).
Of course, two weeks later I find that Toom in Germany has 1 and 2 meter lengths of 25mm steel tubing.
Hi Pascal
I still trying to find the tubs here in my country till now no success.
from where did you order online?
I ordered at rvsonline.nl - https://www.rvsonline.nl/buis-koker-en-massief/rvs-304-geslepen/rvs-304-buis-geslepen
Their site is Dutch, but they’ll help you out in English for sure. They will cut it to length with high precision and ship UPS.
Where do you live?
Hi Dubi I have a similar problem with the lowrider 4 in Israel did you find the right od tubing?
