Community Documentation
Thanks guys. I am no expert so this was really just a few weeks of reading and trying to understand for myself what is going on. I am an engineer, but this is a new topic for me. I was a little disappointed I could not find a write up similar. Most articles are written for all mills and just a few for all router mills… When my aluminum chips started looking like fingernails I knew I was on the right path.
I have a lot more stuff I will put in the forum when I get to it. I am constantly running tests to document and improve performance. But I was confident enough that with a little knowledge, others could duplicate what I have done with a basic machine.
I edited it a little bit in a few places and a little more on the multiple flutes section. I hope it is okay, we can merge it and you can take a look, if you would like me to change anything I will.
Windows/WinTel/Windoze Dev Setup info/hints…
IF, you additionally need to emulate localhost requests as hitting docs.v1engineering.com then…
  • Temporarily while actively coding, edit %windir%\System32\drivers\etc\hosts and add “127.0.0.1 docs.v1engineering.com” mapping if testing cross site scripting.
  • If using Chrome, disable SSL being browser forced. Browse to chrome://net-internals/#hsts enter http://docs.v1engineering.com under Delete domain security policies and press the Delete button.
  • Browsing to http://docs.v1engineering.com:8000 should now hit your Dev locally hosted mkdocs instance.
  • Don’t forget to revert the hosts file edits when done coding/testing.
