I’m having a heck of a time (trying to do things with a Mac). I’m new to this, so it’s probably no surprise. Repetier connects to my board but doesn’t communicate properly. My understanding is that it’s an issue with Repetier. I saw a comment that said CNCjs is a good alternative, so I installed that. The UI looks great on it but it won’t even connect.
I thought I could just use Repetier to create gcode files and put them on an SD card to run but the one I tried didn’t seem to work right. All it did was drive the router down into the table when I was testing the gcode (with the router off). So maybe even creating gcode that way doesn’t work if it doesn’t know what firmware it’s talking to? Or maybe I just didn’t do something right in creating it.
So, I either need to learn how to create appropriate gcode with one of the apps I have or I need an app that will work correctly for me. And then probably I’d need some other help too. My son says I need to know what file type. He says there are some differences based on the controller.
Any advice or help would be appreciated.
