Is there a way to generate an output of the codes that are executed from GRBL?
I don’t think there is a way to get the entire console log, but the console window does show the gcode to grbl and the response (which is mostly ‘ok’).
In addition to @jeffeb3’s reply, these don’t show gcode but you can issue a ? command to get machine current status, and a $$ command to see all the $ configuration settings.
