- Steel cut using my second LowRider v3 that carries a plasma torch.
- Wood cut using my first LowRider v3 that carries a router.
- Cardboard template used for mounting the stand-offs was Sharpie-marked and cut using my first LowRider v3 that carries a router
- LED lights on reverse side to cast a backlight / back-glow on the wall of the enclosure.
- LED remote control has a home on the reverse side using a 3d printed holder I designed.
- LED power supply and LED control box mounted to reverse side using a 3d printed clips I designed.
- Sign mounted to wall of enclosure using 3d printed “stand-offs” I designed. Each has a screw hole in front and two pocket holes in back, oriented at top and bottom.
Multi machine project at it’s finest.
Very neat project thanks for sharing. Those LED’s are so great.
That is awesome! Love the combination of light, steel and wood.
The day I have space to make a second lr3 into a plasma….
What a great mixed process, multi machine build, Doug. Looks great.
And deploy it from a truck ?
(Wishful thinking…)
