I just might. I have a cheapo scope, but I think I can run it from a battery…
Yeah, I might try to break it down for all 32 microsteps in my spreadsheet. Just to see how pecimistic this is. I’m guessing the worst step will vary with speed, but be closer to the middle steps.
Those things are true, but they are problems on the otherside. Determining what torque is fighting the motor is different than maximizing torque output.
Yeah, I understand more than I wanted, for sure. Thanks for dragging me through this.
Sorry to butt in, Ed, Thank you for getting more pictures of my machine in the magazine again!
I am desperately trying to follow along with you two but you went over my head real fast. So I will just sit quietly while the smart guys talk, try to learn a new word or two, Glean some knowledge. It is fun seeing real engineers discuss an issue.
If I plug in 900mA, I get the cutoff moved to 53mm/s.
Torque is proportional to current: at 0.9 A the motor produces only 60% = 0.9/1.5 of its rated 76 oz·in = 45 oz·in.
Power dissipation in the winding resistance varies as the square of the current, so they’re dissipating only 36% of their rated power. Even at 1.5 A, though, they’d dissipate only 5-ish W and shouldn’t get too warm for PLA.
Well thank you but I am more of a persistent bastard, than a smart guy. If I can’t figure it out I just keep trying, a little finger crossing, some cussing, occasionally a plug and pray.
I used this board for my 3D printer, and here the headaches come!
there is no Ramps_16 in marlin source list, so i tried any other boards in configuration but got nothing in the lcd. firmware compiles and uploads successfully via Arduino IDE. however i changed my Arduino board and lcd board (12864 LCD) and still nothing changed.
Maybe the LCD connectors are inverted relative to ramps 1.4. I switched from ramps 1.4 to MKS gen l v1. It should be Pin compatible… But that turned out not to be the case. This video made my day
