Change MPCNC speed
Hello everyone, I have a new laser Neje
A40640 II added. After which the laser is much more powerful than the old one
I want to drive faster Maximum speed is set to
3000mm/min I can change it. (Marlin)
or is it not good for the machine if I work with approx. 6000mm/min
drive ??? LG Gerhard
Should be OK, especially for laser, since there is not any router bit getting friction against material. It’s a no-load speed, basically same as a jog speed.
Thank you for your quick response .
Do you happen to know how and where I can change that?
There is a maximum travel speed set in the Marlin menus, with a default rate compiled into the firmware.
You can set this in the controller menus or with M203
As Dan mentioned, M203
Be sure to enter M500 afterward to save the settings to eprom.
Thank you both! Let’s see if I can find it and change it
can. Habs not so with software. Cheers to Gerhard
Changing speeds? Here you go…
pedals
I feel like those pedals are from this van.
