Machine size: 24x30 w/ 5" z axis
DW660 spindle (no speed control
1/8" 90 degree v bit (2 flute)
Part number: 2002.1250.090 (from drillman1 on ebay)
I will add a video next time I cut, but this stuff cuts like butter. I did some text in estlcam.
Feed was 18 mm/sec,
4.00mm plunge rate 4.00mm depth per pass (it probably went 1-2mm just whatever the carve function had dictated).
The greenware made less dust, but the quality of the engraving was better on bisqueware.
Also did the a mermaid with the same feed/speeds.
The heart is greenware, the plate is bisqueware. I played with the depth on the greenware piece, so ignore the last two letters
Pretty sure it could go much faster or deeper, but that feed was good enough for me.
