Is there a trick to tightening down the bolts/locknuts on the center assembly bearing mounts? Trying to follow the assembly diagram and I can’t seem to get a grip on the locknuts because the mount structure is too close to the nut, but not close enough to hold the locknut in place. Any suggestions?
Nm. I was able to just squeeze a pair of needlenose pliers around it and the bearing mount structure.
Use the force! (Sorry)
