CCJ...Shop Goals for New Year
Get it decluttered/habitable again.
Same here…Hopefully, we can get our garage cleaned out and organized. Get things under control and set up to better suit our needs.
If @Jonathjon keeps on overloading your electric circuits, it just might all burn down, then you don’t have to clean and organize. :stuck_out_tongue:
My shop goals for this year:
  1. Finish my dust collection project that I haven’t finished since I started planning at least since 2023
  1. Make at least one thing with my LR4, which hasn’t happened since Dec 2024
Four at this time:
  1. Clean/reorg so that the most recent acquisitions (jointer, mini lathe, and planer) have homes from which they can be easily used.
  2. Get the K40 laser back up and running, including the motorized Z table and rotary attachment. (This includes adding “drops” for dust collection, and while I’m at it I might as well add a floor sweep, not that the floor has been clear enough to sweep for a while now …)
  3. Extend the size of the MPCNC to be able to take 20"x30" sheets of dollar tree foam for needle cutting RC planes.
  4. Finish setting up my grandfather’s 1934 Craftsman lathe and start using it. This requires me to make a choice between using the original motor, or one salvaged from a treadmill to more easily get variable speed.
Only tripped the breaker 1 time. And that’s what they are meant to do. Have everything spread out between 2 20amp circuits now so all is well :partying_face:
Sigh..
With two and a half benches left to clean, is it too big a task to hope that happens in 2026?
Getting the laser recommissioned and enclosed will be a biggie, as will getting the LR3 dismantled ( :sad_but_relieved_face: ) and the enclosure built and electronics sorted ready for the LR5 in 2027 ! :rofl:
:rofl: :rofl: :rofl:
Keeping the shop organized, setting up dust collection(bought a big delta off Facebook for $20, works great but just in the corner unused for now), make a collapsible wall mount desk to I don’t keep balancing my laptop on paint and trash cans, make a designated place for bits and tool for the cnc. I usually just go “here’s a good spot” and loose them. But the biggest one is organizing the inside shop and make it kiddo and wife usable, well it’s more of a hobby room. The 3d printers,pc and the mpcnc setup with a drag knife.
Side note: both the basement room and the garage my wife calls tinkerland. So if I’m planning on working on stuff my wife asks” Are you going to tinkerland?” Or I tell her “ I’m going to tinkerland.”
I need to clear out all but the top 5 projects in my shop and garage and hopefully get stuff in the hands if others who will use it.
I plan to melt down the failed print pla pile and make flat millable plates for cnc cutting.
I would like to hand off still good stuff like cables, microcontrollers, bolts, and sensors that i will never use to someone else who will use them. Im trying to resist the inner hoarder. I had 4 printers running on Christmas eve. But dont have room for more than 2 long term, so im trying to thin down the collection. One turned back into a pile of parts and one is still in limbo. I want the shop this year to be producing creative stuff, not be a printer/cnc repair shop, which it has been for the last year.
More projects!!!
So close on this one,
I don’t like the base that much. Been futzing with it for a week.
  1. Cleaning it out!
  2. Get the sub panel wired up so the electricity of a little more stable!
  3. Finish the LR3 and get it up and running
  4. Get back into the forge and knifemaking side of my interests!
