Carbon Fiber Tubes
After a mishap with my calipers, I headed down the 25mm path while in the US. The 25mm steel tubing I have found is around $145 per 4’ tube… so that is out.
What is everyone’s thoughts around carbon fiber tubing? I can’t include links, but here is the description for the Amazon items I found that dimensionally should work. (I am not building 4x8’, only doing 2.5x4’)
(1) Carbon Fiber Tube - 25mm x 23mm x 1000mm - 3K Roll Wrapped 100% Carbon Fiber Tube Glossy Surface -(1) Tube
2pcs Carbon Fiber Tube 25mmx23mmx420mm 3K roll Wrapped Twill Matte Finish
I think the consensus is the CF surface will be quickly worn by the bearings riding on it.
Yep, cf tubes won’t work.
