Carbon Fiber Tubes over Stainless Steel Tubing
Would there be any change in using Carbon Fiber instead of Stainless Steel? High Modulus is stronger and stiffer than steel. I’m wondering if there is any wear on the Carbon Fiber after repeated usage? Stainless is quite expensive, then again, so is carbon fiber. But, Carbon Fiber comes in colors too. Just a thought if it would delaminate after long-term use.
Short term. Extremely high point loads form the bearings will kill CF very quickly if not first pass.
Thank you for the feedback. I could have sworn that I had read every single post on these forums, but based on your answer and my recent search results… I should have searched first. Thank you for not bashing me for not doing that first.
I have since realized that Walmart of all places has a 3rd party that sells 25mm x 1m tubing for around $26 each. Plus free shipping.
Thanks again.
