Can I use the G code from carbide create pro g.code on my Marlin LR3 - I tried and I does not seam to work . Any advice will be highly appreciate
There have been a few threads here with interest in this, but as far as I know no one has ever been able to get Marlin to work using Carbide Create Pro.
There are a few more search hits for using Carbide Create Pro with GRBL systems, so there might be hope for using it with a FluidNC controller or one of the GRBL32 controllers.
What is your workflow like, and is there a reason another solution like Estlcam won’t work for your LR3?
can any of the bigtree skr run FluildNC?
No, not possible.
SKRs can run Klipper firmware (there are threads here), with a bit of work and the addition of a Pi or similar Klipper host.
You might want to search the forum some more about Carbide Create Pro, since I don’t use it my ability to advise you is limited.
