Can't Wait, First cut with a Dremel 3000?
ok the machine is mounted, I followed the guides to the drawings. but I have not yet received the spindle so I printed a support for my Dremel 3000 because I can not wait.
So what settings and what tool would you recommend.
I have order and recieve the 1/16" 2 FLUTE CARBIDE ENDMILL, 1/8″ 2 FLUTE CARBIDE LONG and 1/8" SINGLE FLUTE CARBIDE ENDMILL
what speed and step down?
must I set the dremel rotation speed to the maximum?
thanks
I would just follow my guidelines from below.
https://www.v1engineering.com/milling-basics/
Thanks
I did not see it.
I stayed at the getting start and how to…
but my question was most about the dremel and the fact that it is not realy made for routing and milling so I wanted to know what were the settings to succeed a few tests with this dremel without breaking everything
do you think I can use the setting you give into the “For The Impatient” chapter with this tool?
Yup, should get you started.
Hi Jutoto, I have a Dremel 3000 where did you get the support to fit this model?
Cheers,
I used:
And
https://www.thingiverse.com/thing:1675166#
They both work perfectly
