Does anyone use or know of some user friendly software for MAC
Estlcam needs to be run in parallels, AFAIK.
Fusion 360 should work. With the flyfischer post processor.
Kiri:moto is web based, so that should work too.
Thanks, I guess I will try Fusion again , the last time I tried to use the CAM function nothing I did work make it work, I kept getting errors, and I could not tell you what they are now. I guess if I hit any now, I will see if someone has had that issue before.
I have ZERO real life CAM experience, but was mucking around with Kiri:Moto to try to get the hang of CAM and found it pretty Mac user-friendly with a good support network. (I’m a GUI not numbers kind of person).
I had a look at running Parallels, but the cost of the OS and the mucking around was about the same as some of the “lesser” commercial products - depending on your situation “not free” might be a worthwhile option to explore as well.
Please do come back and let’s know what works for you.
Will do! I am messing with Fusion360 right now, looking at just some easy tutorials for like basic cutting for engraving letters.
