Cable routing ideas for MP3DP builds?
Hi everyone,
I’ve been looking through several MP3DP build threads recently and noticed that every builder seems to take a slightly different approach when it comes to cable routing and wiring management.
Since the printer has multiple moving axes and the toolhead moves constantly during printing, cable management becomes quite important for long-term reliability. Poor cable routing can lead to wire fatigue, intermittent connections, or even broken wires after long printing sessions.
Some builds I’ve seen use drag chains for the X and Y axes, while others keep things simple with flexible sleeving and strain relief. I’ve also noticed different approaches around the hotend area where space is limited and the wiring is constantly moving.
A few things I’m curious about from people who have built or modified MP3DP machines:
• Do you prefer drag chains or flexible cable sleeves for the toolhead wiring?
• Have you experienced wiring failures after long printing hours?
• Is it better to keep wiring continuous, or use connectors near the hotend for easier maintenance?
• Any recommended high-flex cables that hold up well over time?
In some machines I’ve worked with outside of the 3D printing space, using high-flex cable and proper strain relief significantly improved reliability for moving equipment. I’m wondering if similar practices apply to MP3DP builds.
It would be great to hear what solutions have worked best for other builders here.
Thanks!
My preference is to use toolheads with USB control, and just sleeves and pre-stressed wire layout instead of chains.
I don’t have any runtime on my repeat printer, but I have over 20,000 hours on TAZ printers without a wire failure.
I avoid connectors in the run.
I’m lucky, I have access to contrahelically wound, silicone jacketed wire- but don’t have a good source for you as what I have is scrap from cables I built at work.
Are you asking because you want to build one or because you want to sell your junction boxes and connectors? :thinking:
I run cables with strain relief at both ends. The MP3DP only has 2 points of movement, the core where the printhead is and the controller end. The Z axis moves up/down so slowly that cable movement is a non-issue.
I was thinking the entire post sounded a bit AI driven, but I wasn’t going to say anything :slight_smile:
Stranded wiring should not have any fatigue issues, regardless of using drag chains or cable sleeves. The more strands in the cable, the less fatigue issues there will be. Solid wire is highly susceptible to fatigue issues. Solder joints may be subject to fatigue.
Connectors are a common point of failure, unless they are positively locked together. An “S-Bend” is needed when there is no positive locking mechanism.
