Cable management question
On the Low Rider 2. I ‘m looking to use some Expandable Braided Sleeving. But what size to order 1/4 3/8 or 1/2" and how much will i need 10’ 20’ ?
I used 1/2" sleeve to do the “tape measure trick” for my X axis. You probably want smaller diameter if you are only fitting the wiring through it.
Hi Robert, can you share stls shown in that picture? I like that solution a lot.
I believe I used this.
Thanks!
I used about 20’ of 1/4" sleeving.
I used about 20’ of 3/8 for the wires in series and 4’ of 1/2" for the ribbon connectors for the LED. Thanks to everyone for the info.
