I have two extension cables for the two 10 pin cables/connectors.
Can someone help with the black 5 pin cable? I can’t see to locate an extension harness.
Maybe if I can identify the connectors/terminal I just build my own harness.
There is a picture in the Docs that shows the black 5 pin cable.
https://docs.v1e.com/electronics/skrpro/#screen-tft35-v3-e3
The wires are the same all the way through (no crossovers), BUT the 5V wire connects to the upper pin on the screen and the lower pin on the SKR board.
Not sure if they are Molex, JST or DuPont connectors, but the spacing is the same.
They are DuPont for the 5 pin wire
I extended one in a really ugly way on a 3D printer. (hand soldered).
Sounding like a broken record recently, this would be a fine task for some clamp lever terminal blocks or the solder sleeves that Ryan sells in the V1 shop.
The giant online book store seems to have compatible stuff a quick search away; here’s a random example that MIGHT work for this.
https://www.amazon.com/Unifizz-Multicolored-Dupont-Terminal-Breadboard/dp/B09QRTCMVS?th=1
Up to a meter size available for $15. 100mm for $7.
If you do this, double then tripple check the pin order and that you don’t flip-flop the signals. Blue smoke will follow.
Also, tape the extension together so it can’t come apart.
