Build in Wisconsin coming together
My crimping method (given that I’m using an el-cheapo non-ratcheting crimping tool):
  1. Strip wire end
  2. Twist wire end
  3. Trim wire end (I always strip more than is needed for some reason, should probably invest in better strippers)
  4. Put wire in crimp end and use needle-nose pliers to squeeze crimp around insulation just enough so it doesn’t fall off when I put it in the crimping tool
  5. Line up in crimping too. Contortions required if I forget to turn the wire in the magic right direction which always feels backwards when I’m doing it.
  6. Crimp
  7. Examine crimp to make sure insulation is held and bare wire is crimped. Multi-meter continuity test if I’m worried.
  8. Trim excess wire at connector end of crimp. Yes, even though I trimmed it before I end up with too much poking out at this point.
  9. Insert into plastic outer connector housing
