Thank you for designing mpcnc and making it available, I am starting my build.
So far I have made the table and cut conduit to length
https://drive.google.com/open?id=1RyesklPstTP2UEZJwV2VRGwdQtcHMJPr
The working dimensions I am planning are 24 x 32 x 4 inches, intended use is for wood
Do you label the lower (closer to table) rails X or Y? I was planning to make the longer axis by the rails closer to the table and maybe put one mid span support in. Does it make a difference which one is x or y if lengths are unequal?
Thank you
Kevin
