Board suggestions for 4-axes setup
Hi community,
at first of course thank you Ryan for all your work and effort you put into that! Just wow!
I’m progressing on building my own MPCNC however a colleague needs some advice on what board to use.
If he uses dual endstops it requires 6 steppers but most boards only offer 5 stepper ports.
So is there a good way to get 6 steppers working to use a 4th axis?
Currently he already owns the following what only allows using 4 stepper motors:
  • Arduino UNO Rev.3 board
  • A4988 driver on a CNC Shield Expansion Board for Arduino
Is there a way to expand that setup? Maybe connect a second CNC shield?
Thanks and regards,
Brian
For dual endstops, you only need 5 steppers, 2 for the X axis, 2 for the Y axis, and 1 for the Z axis. I haven’t delved into the capabilities of the uno or the CNC shield, but it would probably take some effort to make it work since the uno only has a limited number of I/O pins.
I know that it requires 5 steppers for dual endstops. That was not the question.
If you use dual endstops and want to use a 4th axes it requires 6 steppers in total.
The question is how to drive those 6 steppers and is the already available hardware expandable for that goal/purpose?
Most unplug the X or Y axis to use it on the rotary since you won’t need it.
If you do need extra drivers most boards have a few extra broken out that you can manually wire in extra drivers.
