Again …
Save your result with press “Save SVG”.
The .svg will saved in SquiggleDraw folder.
Now open the .svg with Inkscape.
You can scale the Image now.
Then select all, ungroup it. Be sure you can select the lines alone.
Now I delete the outher Frame.
It’s maby possible to make some other Outline or Text, but I don’t test it.
Select all and make Objekt to Path.
Save Image to DXF.
Open DXF in EstlCam.
