Bigger size 3d printer
Hello guys! Is it possible to make a larger size 3d printer like 600x800 or more, height maybe 150mm only? will use it for 3d signage making
What is the largest possible nozzle size so that it will print fast also? signages will be viewed from a far so small detail quality doesn’t matter.
thank you
Sure, totally possible to scale up 3d printers to that size, with caveats. Some commercial stuff out there, try searching “large format 3d printer”.
Print times get very long as you’ve already considered, though. Not to mention filament consumption speed!
1.2mm seems to be a go to nozzle size for large format.
That said. Not sure 3d printing is necessarily the right tool to start with given you’re effectively looking to produce 2.5d (ish) parts and detail quality doesn’t matter. CNC is probably a better fit depending on what your specific designs are.
OP is wanting to do some letters signs with 3d print/liquid acrylic face or laser cut acrylic. Totally doable.
