Belt length - ok to cut a little longer than calculator measurements?
Quick pre/mid-build question - might help someone wondering the same in future.
If I add 5-10cm to the calculator belt length(s) just to be safe, am I able to adjust to cut any excess off later in the build, or should I cut the length to the exact calculator measurements, which maybe have excess calculated already?
Thanks
If you have got enough belt you can do that and cut it later. :slight_smile:
Great, thanks !
On my LR3 (which should be similar), I built a smaller version first, but cut the belts for the eventual larger (longer and wider) version.
The Y belts had an extra 100 cm (3.3’) or so. I just wrapped up the excess at the YMax location, and it never interfered with anything.
The X belt had an extra 40cm (around 16") or so. I wrapped it at the XMin side of the gantry. It was a bit tricky, I had to route the excess into the gantry behind the struts, otherwise it would interfere when the core traveled to XMin.
