Beam Length for Rails
I’m making a 4’x8’ working area. I had a friend cut the beams, but they are a little longer.
The calculator reads
54.625 2 X Rails
106.125 1 Y Rail
But they are 55" and 107" respectively. Does this really matter? Do I need to be exact here?
No, it doesn’t matter as long as the table is big enough, and you have enough belt length.
I have enough belt length and the table is large enough. I recalculated the sizes and 48.4"(X) x 96.9"(Y) will be the exact work area for my 55"x107" rails. My spoilboard is only 4’x8’ though. Should I build it to the original or modify everything for the larger dimension? Am I thinking too hard about it?
I have something similar. A 4x8 machine, but it is just a little bigger like yours. I didn’t resize the “bed” size to match. I just used a 4x8 spoilboard.
Ok cool, thanks for your help. So, I feel like I should use the larger dimensions from the calculator to match the 55"x107" beams and keep everything else as is. I’m nearly done, just have to assemble everything to the rails and then cut the strut plates. One last thing, do I need to modify the temporary strut plates or can I use those regardless of size?
You will need to go up in the calculator until it shows the X rails at the length you have. That way you end up with the correct length struts. If you cut your struts for a straight 48" cut, your pipes will be too long and things will bind.
You can use those as is for now. When you go to cut the actual plate, just use the correct numbers you have now.
So the sizes will be 48.4"(X) x 96.9"(Y) respectively newly calculated. I printed my temporary strut plates from the makerworld v1 Engineering page. Do I need to modify the temporary strut plates? Or will these be fine regardless? I have a 3D printer, but I imagine if someone just bought the parts, they would have to use the temporary struts regardless as they are?
Sorry about that. Skimmed too fast :man_facepalming:
No worries!
