My new MPCNC is about 80% assembled (thanks to Ryan and others answering some basic questions with patience and tolerance
Time to get ready by purchasing some cutting tools. I have a Dremel 4000 and a Makita router that I will be using as the milling device, and I would appreciate some advice on what cutters to buy to start with.
My aims are to Firstly:
cut parts for rc boats and planes out of balsa and 3mm or so ply
Cut parts out of MDF and ply up to 3/4 inch or so
Later:
Try some 3d carving
Make signs
Mill aluminium parts
These are the dream aims - as a beginner I figure I’ve got a lot to learn before I attempt some of these things and intend to take it in baby steps!
I’d like to know what cutters to start with…apart from what appears to be the ubiquitous 1/8" singe flute upcut…
The single flute upcut will do most of the work, thin stuff might do better with a downcut. Everything else is kinda specialized. Ball is mostly for 3D (2.5D) carving, V bit are more for marking and engraving-ish stuff.
I buy 10 packs mostly because Ryan doesnt carry .8mm or 1.6mm bits or the length I need. They work fine but are very brittle at that size so I go through quite a few. The kyocera bits Ryan caries are much sharper and last longer than most of the 10 pack bits I have gotten.
Thanks for the suggestions guys. I’ve ordered a set of 10 1/8" bits via Ebay, I’ll get some quality bits once I learn how to drive my MPCNC. I’m now at the wiring stage having assembled my kit and build a table for it. Going away for Easter so will be next week before it is completed.
