I have an MPCNC Primo with SKR Pro V1.2 I purchased from someone. Worked when I bought it but later when I tried to auto home, it broke both Y axis carriages. This was caused by 1- the wrong connectors for the limit switches and 2- missing (not sure of this) missing VALIDATE_HOMEING_ENDSTOPS and DETECT_BROKEN_ENDSTOP.
What happened, due to the bad connector is one of the Y axis limit switches was not connected, telling the firmware that side was homed. The other limit switch worked so the firmware told that motor to go home. This resulted in the axis skewing, staling the motor and breaking/splitting both Y axis carriages.
I contacted the Marlin Github group they recommended enabling the above options. They suggested not having these enabled caused the problem. They also suggested setting max steps during homing as well though its not clear what that would do.
I thought having a max steps the second axis to home was allowed to move before a failure was detected. I haven’t checked to see exactly what the Validate/Detect options above do.
I’m not sure where to find the current config files being used by V1, for the SKR Pro. The information would be helpful as it would allow building the current version of Marlin.
That said, I think this will be a problem for any controller using dual endstops/switches.
The V1 and Marlin projects are simply amazing, V1 in particular since there isn’t a huge group supporting Ryan. Course that could just be my ignorance showing.
Regards,
Jim Brooks
