When I issue a “$$” command in the console, below are all the config options that I am presented with. Perhaps something there will spark an idea?
[fb] firmware build 101.03
[fv] firmware version 0.99
[fbs] firmware build 101.03-18-ge1b5a
[fbc] firmware config settings_default.h
[hp] hardware platform ArduinoDue
[hv] hardware version na
[id] g2core ID 0084-7bd6-0084-18c
[jt] junction integration time 0.75
[ct] chordal tolerance 0.0100 mm
[zl] Z lift on feedhold 0.000 mm
[sl] soft limit enable 0 [0=disable,1=enable]
[lim] limit switch enable 0 [0=disable,1=enable]
[saf] safety interlock enable 0 [0=disable,1=enable]
[m48] overrides enabled 1 [0=disable,1=enable]
[froe] feed override enable 0 [0=disable,1=enable]
[fro] feedrate override 1.000 [0.05 < mfo < 2.00]
[troe] traverse over enable 0 [0=disable,1=enable]
[tro] traverse override 1.000 [0.05 < mto < 1.00]
[mt] motor idle timeout 1000.00 seconds
[tv] text verbosity 1 [0=silent,1=verbose]
[ej] enable json mode 0 [0=text,1=JSON,2=auto]
[jv] json verbosity 4 [0=silent,1=footer,2=messages,3=configs,4=linenum,5=verbose]
[qv] queue report verbosity 1 [0=off,1=single,2=triple]
[sv] status report verbosity 1 [0=off,1=filtered,2=verbose]
[si] status interval 100 ms
[gpl] default gcode plane 0 [0=G17,1=G18,2=G19]
[gun] default gcode units mode 1 [0=G20,1=G21]
[gco] default gcode coord system 1 [1-6 (G54-G59)]
[gpa] default gcode path control 2 [0=G61,1=G61.1,2=G64]
[gdi] default gcode distance mode 0 [0=G90,1=G91]
[1ma] m1 map to axis 0 [0=X,1=Y,2=Z...]
[1sa] m1 step angle 1.800 deg
[1tr] m1 travel per revolution 1.2500 mm
[1su] m1 steps per unit 1280.00000 steps per mm
[1mi] m1 microsteps 8 [1,2,4,8,16,32]
[1po] m1 polarity 0 [0=normal,1=reverse]
[1pm] m1 power management 1 [0=disabled,1=always on,2=in cycle,3=when moving]
[1pl] m1 motor power level 1.000 [0.000=minimum, 1.000=maximum]
[1ep] m1 enable polarity 0 [0=active HIGH,1=active LOW]
[1sp] m1 step polarity 1 [0=active HIGH,1=active LOW]
[2ma] m2 map to axis 1 [0=X,1=Y,2=Z...]
[2sa] m2 step angle 1.800 deg
[2tr] m2 travel per revolution 40.0000 mm
[2su] m2 steps per unit 40.00000 steps per mm
[2mi] m2 microsteps 8 [1,2,4,8,16,32]
[2po] m2 polarity 0 [0=normal,1=reverse]
[2pm] m2 power management 1 [0=disabled,1=always on,2=in cycle,3=when moving]
[2pl] m2 motor power level 1.000 [0.000=minimum, 1.000=maximum]
[2ep] m2 enable polarity 1 [0=active HIGH,1=active LOW]
[2sp] m2 step polarity 1 [0=active HIGH,1=active LOW]
[3ma] m3 map to axis 2 [0=X,1=Y,2=Z...]
[3sa] m3 step angle 1.800 deg
[3tr] m3 travel per revolution 1.2500 mm
[3su] m3 steps per unit 1280.00000 steps per mm
[3mi] m3 microsteps 8 [1,2,4,8,16,32]
[3po] m3 polarity 1 [0=normal,1=reverse]
[3pm] m3 power management 1 [0=disabled,1=always on,2=in cycle,3=when moving]
[3pl] m3 motor power level 1.000 [0.000=minimum, 1.000=maximum]
[3ep] m3 enable polarity 0 [0=active HIGH,1=active LOW]
[3sp] m3 step polarity 0 [0=active HIGH,1=active LOW]
[4ma] m4 map to axis 3 [0=X,1=Y,2=Z...]
[4sa] m4 step angle 1.800 deg
[4tr] m4 travel per revolution 360.0000 mm
[4su] m4 steps per unit 4.44444 steps per mm
[4mi] m4 microsteps 8 [1,2,4,8,16,32]
[4po] m4 polarity 0 [0=normal,1=reverse]
[4pm] m4 power management 0 [0=disabled,1=always on,2=in cycle,3=when moving]
[4pl] m4 motor power level 0.000 [0.000=minimum, 1.000=maximum]
[4ep] m4 enable polarity 0 [0=active HIGH,1=active LOW]
[4sp] m4 step polarity 1 [0=active HIGH,1=active LOW]
[xam] x axis mode 1 [standard]
[xvm] x velocity maximum 1000 mm/min
[xfr] x feedrate maximum 1000 mm/min
[xtn] x travel minimum 0.000 mm
[xtm] x travel maximum 0.000 mm
[xjm] x jerk maximum 1000 mm/min^3 * 1 million
[xjh] x jerk homing 1000 mm/min^3 * 1 million
[xhi] x homing input 0 [input 1-N or 0 to disable homing this axis]
[xhd] x homing direction 0 [0=search-to-negative, 1=search-to-positive]
[xsv] x search velocity 500 mm/min
[xlv] x latch velocity 100.00 mm/min
[xlb] x latch backoff 4.000 mm
[xzb] x zero backoff 2.000 mm
[yam] y axis mode 1 [standard]
[yvm] y velocity maximum 1000 mm/min
[yfr] y feedrate maximum 1000 mm/min
[ytn] y travel minimum 0.000 mm
[ytm] y travel maximum 0.000 mm
[yjm] y jerk maximum 1000 mm/min^3 * 1 million
[yjh] y jerk homing 1000 mm/min^3 * 1 million
[yhi] y homing input 0 [input 1-N or 0 to disable homing this axis]
[yhd] y homing direction 0 [0=search-to-negative, 1=search-to-positive]
[ysv] y search velocity 500 mm/min
[ylv] y latch velocity 100.00 mm/min
[ylb] y latch backoff 4.000 mm
[yzb] y zero backoff 2.000 mm
[zam] z axis mode 1 [standard]
[zvm] z velocity maximum 1000 mm/min
[zfr] z feedrate maximum 1000 mm/min
[ztn] z travel minimum -1000.000 mm
[ztm] z travel maximum 1000.000 mm
[zjm] z jerk maximum 500 mm/min^3 * 1 million
[zjh] z jerk homing 500 mm/min^3 * 1 million
[zhi] z homing input 0 [input 1-N or 0 to disable homing this axis]
[zhd] z homing direction 0 [0=search-to-negative, 1=search-to-positive]
[zsv] z search velocity 250 mm/min
[zlv] z latch velocity 25.00 mm/min
[zlb] z latch backoff 4.000 mm
[zzb] z zero backoff 2.000 mm
[uam] u axis mode 0 [disabled]
[uvm] u velocity maximum 1000 mm/min
[ufr] u feedrate maximum 1000 mm/min
[utn] u travel minimum 0.000 mm
[utm] u travel maximum 0.000 mm
[ujm] u jerk maximum 1000 mm/min^3 * 1 million
[ujh] u jerk homing 1000 mm/min^3 * 1 million
[uhi] u homing input 0 [input 1-N or 0 to disable homing this axis]
[uhd] u homing direction 0 [0=search-to-negative, 1=search-to-positive]
[usv] u search velocity 500 mm/min
[ulv] u latch velocity 100.00 mm/min
[ulb] u latch backoff 4.000 mm
[uzb] u zero backoff 2.000 mm
[vam] v axis mode 0 [disabled]
[vvm] v velocity maximum 1000 mm/min
[vfr] v feedrate maximum 1000 mm/min
[vtn] v travel minimum 0.000 mm
[vtm] v travel maximum 0.000 mm
[vjm] v jerk maximum 1000 mm/min^3 * 1 million
[vjh] v jerk homing 1000 mm/min^3 * 1 million
[vhi] v homing input 0 [input 1-N or 0 to disable homing this axis]
[vhd] v homing direction 0 [0=search-to-negative, 1=search-to-positive]
[vsv] v search velocity 500 mm/min
[vlv] v latch velocity 100.00 mm/min
[vlb] v latch backoff 4.000 mm
[vzb] v zero backoff 2.000 mm
[wam] w axis mode 0 [disabled]
[wvm] w velocity maximum 1000 mm/min
[wfr] w feedrate maximum 1000 mm/min
[wtn] w travel minimum 0.000 mm
[wtm] w travel maximum 0.000 mm
[wjm] w jerk maximum 500 mm/min^3 * 1 million
[wjh] w jerk homing 500 mm/min^3 * 1 million
[whi] w homing input 0 [input 1-N or 0 to disable homing this axis]
[whd] w homing direction 0 [0=search-to-negative, 1=search-to-positive]
[wsv] w search velocity 250 mm/min
[wlv] w latch velocity 25.00 mm/min
[wlb] w latch backoff 4.000 mm
[wzb] w zero backoff 2.000 mm
[aam] a axis mode 0 [disabled]
[avm] a velocity maximum 288000 deg/min
[afr] a feedrate maximum 288000 deg/min
[atn] a travel minimum -1.000 deg
[atm] a travel maximum -1.000 deg
[ajm] a jerk maximum 288000 deg/min^3 * 1 million
[ajh] a jerk homing 288000 deg/min^3 * 1 million
[ara] a radius value 57.2957 deg
[ahi] a homing input 0 [input 1-N or 0 to disable homing this axis]
[ahd] a homing direction 0 [0=search-to-negative, 1=search-to-positive]
[asv] a search velocity 144000 deg/min
[alv] a latch velocity 28800.00 deg/min
[alb] a latch backoff 5.000 deg
[azb] a zero backoff 2.000 deg
[bam] b axis mode 0 [disabled]
[bvm] b velocity maximum 288000 deg/min
[bfr] b feedrate maximum 288000 deg/min
[btn] b travel minimum -1.000 deg
[btm] b travel maximum -1.000 deg
[bjm] b jerk maximum 288000 deg/min^3 * 1 million
[bjh] b jerk homing 288000 deg/min^3 * 1 million
[bra] b radius value 57.2957 deg
[bhi] b homing input 0 [input 1-N or 0 to disable homing this axis]
[bhd] b homing direction 0 [0=search-to-negative, 1=search-to-positive]
[bsv] b search velocity 144000 deg/min
[blv] b latch velocity 28800.00 deg/min
[blb] b latch backoff 5.000 deg
[bzb] b zero backoff 2.000 deg
[cam] c axis mode 0 [disabled]
[cvm] c velocity maximum 288000 deg/min
[cfr] c feedrate maximum 288000 deg/min
[ctn] c travel minimum -1.000 deg
[ctm] c travel maximum -1.000 deg
[cjm] c jerk maximum 288000 deg/min^3 * 1 million
[cjh] c jerk homing 288000 deg/min^3 * 1 million
[cra] c radius value 57.2957 deg
[chi] c homing input 0 [input 1-N or 0 to disable homing this axis]
[chd] c homing direction 0 [0=search-to-negative, 1=search-to-positive]
[csv] c search velocity 144000 deg/min
[clv] c latch velocity 28800.00 deg/min
[clb] c latch backoff 5.000 deg
[czb] c zero backoff 2.000 deg
[di1mo] input mode 0 [0=active-low,1=active-hi,2=disabled]
[di1ac] input action 0 [0=none,1=stop,2=fast_stop,3=halt,4=alarm,5=shutdown,6=panic,7=reset]
[di1fn] input function 0 [0=none,1=limit,2=interlock,3=shutdown,4=probe]
[di2mo] input mode 0 [0=active-low,1=active-hi,2=disabled]
[di2ac] input action 0 [0=none,1=stop,2=fast_stop,3=halt,4=alarm,5=shutdown,6=panic,7=reset]
[di2fn] input function 0 [0=none,1=limit,2=interlock,3=shutdown,4=probe]
[di3mo] input mode 0 [0=active-low,1=active-hi,2=disabled]
[di3ac] input action 0 [0=none,1=stop,2=fast_stop,3=halt,4=alarm,5=shutdown,6=panic,7=reset]
[di3fn] input function 0 [0=none,1=limit,2=interlock,3=shutdown,4=probe]
[di4mo] input mode 0 [0=active-low,1=active-hi,2=disabled]
[di4ac] input action 0 [0=none,1=stop,2=fast_stop,3=halt,4=alarm,5=shutdown,6=panic,7=reset]
[di4fn] input function 0 [0=none,1=limit,2=interlock,3=shutdown,4=probe]
[di5mo] input mode 0 [0=active-low,1=active-hi,2=disabled]
[di5ac] input action 0 [0=none,1=stop,2=fast_stop,3=halt,4=alarm,5=shutdown,6=panic,7=reset]
[di5fn] input function 4 [0=none,1=limit,2=interlock,3=shutdown,4=probe]
[di6mo] input mode 0 [0=active-low,1=active-hi,2=disabled]
[di6ac] input action 0 [0=none,1=stop,2=fast_stop,3=halt,4=alarm,5=shutdown,6=panic,7=reset]
[di6fn] input function 0 [0=none,1=limit,2=interlock,3=shutdown,4=probe]
[di7mo] input mode 0 [0=active-low,1=active-hi,2=disabled]
[di7ac] input action 0 [0=none,1=stop,2=fast_stop,3=halt,4=alarm,5=shutdown,6=panic,7=reset]
[di7fn] input function 0 [0=none,1=limit,2=interlock,3=shutdown,4=probe]
[di8mo] input mode 0 [0=active-low,1=active-hi,2=disabled]
[di8ac] input action 0 [0=none,1=stop,2=fast_stop,3=halt,4=alarm,5=shutdown,6=panic,7=reset]
[di8fn] input function 0 [0=none,1=limit,2=interlock,3=shutdown,4=probe]
[di9mo] input mode 1 [0=active-low,1=active-hi,2=disabled]
[di9ac] input action 0 [0=none,1=stop,2=fast_stop,3=halt,4=alarm,5=shutdown,6=panic,7=reset]
[di9fn] input function 0 [0=none,1=limit,2=interlock,3=shutdown,4=probe]
[do1mo] output mode 2 [0=active low,1=active high,2=disabled]
[do2mo] output mode 2 [0=active low,1=active high,2=disabled]
[do3mo] output mode 2 [0=active low,1=active high,2=disabled]
[do4mo] output mode 2 [0=active low,1=active high,2=disabled]
[do5mo] output mode 2 [0=active low,1=active high,2=disabled]
[do6mo] output mode 2 [0=active low,1=active high,2=disabled]
[do7mo] output mode 2 [0=active low,1=active high,2=disabled]
[do8mo] output mode 2 [0=active low,1=active high,2=disabled]
[do9mo] output mode 2 [0=active low,1=active high,2=disabled]
[p1frq] pwm frequency 100 Hz
[p1csl] pwm cw speed lo 7900 RPM
[p1csh] pwm cw speed hi 12800 RPM
[p1cpl] pwm cw phase lo 0.130 [0..1]
[p1cph] pwm cw phase hi 0.170 [0..1]
[p1wsl] pwm ccw speed lo 7900 RPM
[p1wsh] pwm ccw speed hi 12800 RPM
[p1wpl] pwm ccw phase lo 0.130 [0..1]
[p1wph] pwm ccw phase hi 0.170 [0..1]
[p1pof] pwm phase off 0.100 [0..1]
[g54x] g54 x offset 0.000 mm
[g54y] g54 y offset 0.000 mm
[g54z] g54 z offset 0.000 mm
[g54u] g54 u offset 0.000 mm
[g54v] g54 v offset 0.000 mm
[g54w] g54 w offset 0.000 mm
[g54a] g54 a offset 0.000 deg
[g54b] g54 b offset 0.000 deg
[g54c] g54 c offset 0.000 deg
[g55x] g55 x offset 0.000 mm
[g55y] g55 y offset 0.000 mm
[g55z] g55 z offset 0.000 mm
[g55u] g55 u offset 0.000 mm
[g55v] g55 v offset 0.000 mm
[g55w] g55 w offset 0.000 mm
[g55a] g55 a offset 0.000 deg
[g55b] g55 b offset 0.000 deg
[g55c] g55 c offset 0.000 deg
[g56x] g56 x offset 0.000 mm
[g56y] g56 y offset 0.000 mm
[g56z] g56 z offset 0.000 mm
[g56u] g56 u offset 0.000 mm
[g56v] g56 v offset 0.000 mm
[g56w] g56 w offset 0.000 mm
[g56a] g56 a offset 0.000 deg
[g56b] g56 b offset 0.000 deg
[g56c] g56 c offset 0.000 deg
[g57x] g57 x offset 0.000 mm
[g57y] g57 y offset 0.000 mm
[g57z] g57 z offset 0.000 mm
[g57u] g57 u offset 0.000 mm
[g57v] g57 v offset 0.000 mm
[g57w] g57 w offset 0.000 mm
[g57a] g57 a offset 0.000 deg
[g57b] g57 b offset 0.000 deg
[g57c] g57 c offset 0.000 deg
[g58x] g58 x offset 0.000 mm
[g58y] g58 y offset 0.000 mm
[g58z] g58 z offset 0.000 mm
[g58u] g58 u offset 0.000 mm
[g58v] g58 v offset 0.000 mm
[g58w] g58 w offset 0.000 mm
[g58a] g58 a offset 0.000 deg
[g58b] g58 b offset 0.000 deg
[g58c] g58 c offset 0.000 deg
[g59x] g59 x offset 0.000 mm
[g59y] g59 y offset 0.000 mm
[g59z] g59 z offset 0.000 mm
[g59u] g59 u offset 0.000 mm
[g59v] g59 v offset 0.000 mm
[g59w] g59 w offset 0.000 mm
[g59a] g59 a offset 0.000 deg
[g59b] g59 b offset 0.000 deg
[g59c] g59 c offset 0.000 deg
[g92x] g92 x offset 0.000 mm
[g92y] g92 y offset 0.000 mm
[g92z] g92 z offset 0.000 mm
[g92u] g92 u offset 0.000 mm
[g92v] g92 v offset 0.000 mm
[g92w] g92 w offset 0.000 mm
[g92a] g92 a offset 0.000 deg
[g92b] g92 b offset 0.000 deg
[g92c] g92 c offset 0.000 deg
[g28x] g28 x position 0.000 mm
[g28y] g28 y position 0.000 mm
[g28z] g28 z position 0.000 mm
[g28u] g28 u position 0.000 mm
[g28v] g28 v position 0.000 mm
[g28w] g28 w position 0.000 mm
[g28a] g28 a position 0.000 deg
[g28b] g28 b position 0.000 deg
[g28c] g28 c position 0.000 deg
[g30x] g30 x position 0.000 mm
[g30y] g30 y position 0.000 mm
[g30z] g30 z position 0.000 mm
[g30u] g30 u position 0.000 mm
[g30v] g30 v position 0.000 mm
[g30w] g30 w position 0.000 mm
[g30a] g30 a position 0.000 deg
[g30b] g30 b position 0.000 deg
[g30c] g30 c position 0.000 deg
g2core[mm] ok>
